Anyone has any suggestions on heated gear, brands, watts...??? My wife and I ride back and forth between Florida and Michigan. Next summer were are planning a trip to Alaska. I want to make sure that cold weather does not stop us from riding. We are used to high 30s without heated gear but it sure would be nice to keep riding with temp. below 30s. Any suggestions... Thanks,
Ivan |
I am in the market for some heated gear also and will look
hard at Gerbing for no other reason than their factory is close and I was an early customer back in the middle 90's The wattage issue seems to come up a lot on the forums. I guess with stock alternator output your limited to how warm and cozy you can get. Quite a few good threads in the last year. |
You won't go wrong with Gerbing. I've been using their liner and gloves for probably 15 years. Their customer service has been great. The only problem I've had was some stitching in one sleeve came loose. I called Gerbing...they said "we'll send you an new liner and just return the defective one when you receive the new one." They paid shipping both ways. Good trusting folks. I've ridden in temps down to the lower 20's using their liner under my Olympia mesh jacket (AirGlide I believe). When not needed it takes very little space in my tankbag. I've heard good things about Warm-n-Safe as well.
I agree. You can not go wrong with Gerbing. I have been using a complete set..... jacket, pants, gloves and socks. The quality is very good and so far they have been very responded to all of our issues.
Everything is water proof and all the liners come out for nice shells in warmer weather. I can ride down to around freezing (32*) and stay relatively warm. Great feature .... If you have a favorite jacket that has a liner you can send the liner to Gerbing and they will heat it. My 07 12GS is rated around 750 watts .... plenty to run everything on the bike and heated clothing. |
Love my Tourmaster Synergy vest with collar. Not bad for $125! Buy the BMW adaptor as it has a telephone-cord style connector that allows you to move around on the seat much more than a traditional chord. As with all vests, the CANBUS will trip when you plug it into the accessory port beside the seat. So just wire that plug directly to the battery with an online fuse and no problems!
