Don't know exactly how much hp would increase with cats & muff removed. If you did this, you would also need to have the cpu/fuel inj remapped as the engine would likely lean out w/o normal back pressure.
The hp on the 08's is up to 108 (or there about),...I don't know why you would need more? |
Im with you, its got good power but I for one would like to get moe out of it. You can never have to much. First and second gear wheelies are good but third gear wheelies are better.
Hi all, ive had 3 gs's but this is my first post on this site!!!
I too am looking for a bump in power as finances dictate that other than a new one!!! I have a K&N Air filter and a wunderluch air charger now and am soon to buy a power commander and full remus system. If I fit the filter and charger before i do the remap would i (a) make the bike run too lean and do damage and (b) get any difference in power? Thanks in advance for any help you could offer.. |
at the rear wheel, i did have the torque curve but the sheet has gone to the new owner, same thing with GS motors with every other motor, you got to get more in and more out and with the air intake snorkle as small as it is its maxed out at about 5500 with the wunderlich snorkle it flow about 100% more air, more in more out
