I have just bought a second hand 2004 R1200 GS, and must say I'm very pleaased with it...except that the high beam is pointing way up into the trees. Low beam seems to be pointing on the road OK. I have looked closely in and around the back of the light housing for an adjuster, and found the knobs on the bottom centre and the one top right. I can't make these adjust the high beam in any significant way without throwing out the low beam lioght position. Any help would be aprpeciated. Ciao Pedro (Bendigo, Victoria, Australia)
Make sure the internal headlight framework is seated properly in the adjustment linkage. When replacing a bulb with my big hands, with limited light, and new to the bike, I pushed too hard and popped the ball out of the socket. When you pull the rubber cover off to get to the lightbulb, see if the reflector jiggles around. If it does, it needs to be re-seated.
I ended up taking the headlight assemply off of the bike and I think I had to fasion a hook-like thingie to reach in and pull the internal framework back into the external housing. Pop! and it was fixed. It just took two hours to figure it out and two seconds to do it.
D Haun 2007 R1200GS Austin, Texas |
