Hepco&Becker Tank crash bar - crooked? - BMW R1200GS Forum : R1200 GS Forums
Old 25-Sep-2008, 11:34 AM (690)
Default Hepco&Becker Tank crash bar - crooked?
Hi folks,
I've bought a H&B tank crash bar from wunderlich.
I've tried installing it today, without much luck. It seems to me, that whole thing is crooked/bent/asymmetrical/out-of-alignment - see it here
My lower crash bar is the original BMW one - as far as I can tell, it's completely symmetrical (even if the engine isn't )
Anyone here got this crash bar installed? I'm I correct: "It's supposed to be symmetrical?"
Old 05-Oct-2008, 07:41 AM (528)
I have the H&B tank guard and engine guard installed together. i don't think you can install the H&B tank guard with the OEM engine guard. I had the OEM engine guard and replaced it with the H&B one which is more sturdy IMHO. The OEM one was bent after the bike fell over after I tried to park it on a hill. No damage to the bike but the OEM guard became slightly twisted. Yes the engine is not symetrical so the H&B guards are not as well. Mine fitted without a problem.
Old 06-Oct-2008, 12:02 PM (710)
Default solved
Thanks - I sent it back for a refund.
Old 07-May-2009, 04:04 AM (377)
I am sorry to say that my bars had a very ill fitting process too.
I called CAL & was told that this was IT. Sure enough it was IT.
They were harder that I would have expected to mate to the original but worth the cussing.
The nuts & bolts were "butter bolts" many broke at the head & threads were stretched. Had to replace the "butter bolts w/ grade 8s, allen heads & better locking nuts. Since, I have helped another GS rider w/ his set of bars & things went as expected, hard & still a poor fit, but much faster w/ another set of hands.
Standard are falling.
Old 09-May-2009, 03:24 AM (350)
Default Life is an adjustment
Bought the BMW OEM aluminium cylinder head protectors. Great idea I thought.
Bought the H&B Engine & tank guards. Didn't fit with the BMW cylinder guard did they?
A few spacers, a lot of swearing & the problem was solved. Celebrated by a glass of red wine!
"Problems are just solutions in disguise".
