I want to install two Powerlet Sockets into the area of the 1200's frame where winglets are placed (one on each side). I know that under the frame surface are circular indents for the actual holes. My question is: in order to be certain the holes are drilled & centered within these indents, can this frame section of the bike be removed and turned over to drill, or is there a procedure to drill these holes from the "bottom up" centered within these circular indents?
Color in the center of the indents with a black marker, then shine a bright flashlight thru from the bottom. Use a center punch to marker the center and drill in place.
2007 R1200GS Last edited by rcliffor; 29-Jul-2009 at 06:09 AM (464). |
I suggest that you take clean power directly from the battery with an in-line fuse for the power outlets. Some accessories will freak out the Can-bus and get shut down. My seat outlet is Can-bus, but the two fronts aren't.
