Front end rebuild question - BMW R1200GS Forum : R1200 GS Forums
 4Likes
  • 1 Post By JetSpeed
  • 1 Post By Sed8r
  • 1 Post By Sed8r
post #1 of 9 (permalink) Old 17-Dec-2016, 07:06 PM (046) Thread Starter
Sed8r's Avatar
Location: Washington, Idaho, Utah, Maryland, Nevada, Mississippi, Germany, Alaska, Texas, Italy...
Rebuilding front forks - got the new stanchions today and installed them. There seems to be a problem - they don't depress into the slide tube (lower part of the forks) all the way. I've taken them apart and reassembled exactly as shown in the service manual (off the bike, so there is no binding with the axle or fork bridge - each of them, separately do not go down - they seem to bottom out on something. I know there are spacers and a bushing in each of the slider tubes - certainly those shouldn't be a problem, should they? I'm at a loss. Yes, I've removed the bleeder screw so it wasn't air pressure keeping them from compressing, and yes, I've re-built front suspensions before on other bikes. Technically - those should be more difficult (and were - though hardly "difficult"), as there are no springs or valves in the forks of the '16 R1200GS LC Adventure.
Any ideas? I'm scratching my head.
“There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.” -- Ernest Hemingway
Sed8r is offline
post #2 of 9 (permalink) Old 18-Dec-2016, 12:00 AM (250)
bmwbob51's Avatar
Manual
BMW R1200 '13 to '16 Liquid-cooled Twins (Haynes Service & Repair Manual)
bmwbob51 is offline
post #3 of 9 (permalink) Old 18-Dec-2016, 07:14 AM (551) Thread Starter
Sed8r's Avatar
Thanks, but I have the BMW repair and service data disc manual already.
Sed8r is offline
post #4 of 9 (permalink) Old 18-Dec-2016, 09:16 AM (636)
When you say "rebuild" how far down did you take the forks? Are you just replacing the forks (stanchions)?
Do you have the correct part # forks (31428566596)?
Sed8r likes this.
post #5 of 9 (permalink) Old 18-Dec-2016, 01:57 PM (831) Thread Starter
Sed8r's Avatar
Hey JetSpeed - I was actually hoping you'd chime in, you seem pretty knowledgeable. Yeah, I ordered them from BMWeStore
Part Status Description Quantity Price
31428566596 Stanchion 2 $438.25
The part #was updated by BMW later this year. I got that from several BMW places I contacted (ASCYCLES.COM, BIKEBANDIT etc) and nobody else had them in stock. The new # is what the dealers can get a hold of, and the only one BMW is manufacturing, supposedly. Still, I can't figure why they don't compress at all...
JetSpeed likes this.
Sed8r is offline
post #6 of 9 (permalink) Old 18-Dec-2016, 04:22 PM (932)
Sounds like you have the correct parts, I have a few questions:
What is the reason for replacing the stanchions, I am assuming damaged (bent)?
When you pulled the old stanchions out did they come out with much resistance?
Did you leave the guides and seals, bushings and spacers all in the the slider tubes?
How far in do the stanchions slide before they stop?
My suspicion is that the bushing (guide element) that is located about 3/5's down the slider is causing the hang-up.
Sed8r likes this.
post #7 of 9 (permalink) Old 18-Dec-2016, 07:15 PM (052) Thread Starter
Sed8r's Avatar
They were bent, yep. Only the upper portion though, and when they were taken off the bike - I removed the nut at the steering mount and had removed the bleed screw - they easily slid down the lower slide tubes (until the bend) and stopped. Many inches lower than the current new straight tubes slide. It's confusing as heck. The old tubes pulled straight out too - no problems - and I checked the bottom of them and the lower slide tubes with my starrett machinist straight edge and they are perfectly straight as far as my eyes and feeler gauges can tell. The new stanchions only go in far enough to mount the lower slide tubes back at the correct level in the lower triple tree (or whatever you call where the telelever thing attaches). Yeah - I wondered about that bushing, and that's about the right distance, the only thing I can't make sense of is why the install instructions don't say anything about taking any of the internal stuff out of the lower slide tube. I'll have to take them off and dump the oil and pull out the stuff and see if it took some damage somehow that's stopping the new tubes, yet let the old tubes compress...
If I can figure it out (or hear back from BMWestore) I'll post up what I find out. Thanks, JetSpeed - I'll give it a look tomorrow!
Sed8r is offline
post #8 of 9 (permalink) Old 19-Dec-2016, 08:41 AM (612)
I think that you have the right idea.
If the inside bushing is the issue you may be able to swap it with the upper bushing (same part) but you will need the special tool (Bushing impact sleeve installer) that will run you near $150 for both pieces.
I think that you're going to need to remove all the guts from the forks to get this sorted, something is either damaged or out of position.
Keep us posted.
post #9 of 9 (permalink) Old 19-Dec-2016, 12:32 PM (772) Thread Starter
Sed8r's Avatar
Seems to hang up at the level of the bushing. I'm just going to re order new internals and replace it all. I'll post up how it goes when they get here and go in.
Sed8r is offline
