20K Service - Dealer or Other Shop? - BMW R1200GS Forum : R1200 GS Forums
 4Likes
  • 2 Post By slowriding
  • 2 Post By Houdini
post #1 of 8 (permalink) Old 23-Dec-2016, 03:02 AM (376) Thread Starter
I have done about 7000km since October and my 1200GS is now approaching its 20K service.
It is a 2012 model - therefore no warranty any more.
What should I do? Take it to the dealer ($$$) or get someone else to service the bike?
There is a bike shop about 20 min from us that I have used for general stuff a couple of times. I like the fact that they dont mind me watching and (sometimes) helping when they work on the bike.
Items on the 20K service list that needs to be done:
- Valve clearances
- Secondary Spark Plug Check
- Engine starting interlock check (whatever the hell this might be.....)
- Throttle valve cables check
- Fault Code Reading
- Charge AGM Battery (????)
I have done the oil / oil filter and air filter. The rest of the general checks is not really a problem.
This brings me to another issue - said bike shop cannot reset the service warning.
I am also thinking of getting one of those GS911 gadgets. Apparently the GS9111 can reset the service warning and give you a whole bunch of other diagnostic info.
Does anyone here have experience with the GS911?
=DUKE= is offline
post #2 of 8 (permalink) Old 23-Dec-2016, 05:41 AM (487)
Items needed for the 20,000km (12,000 miles) service are:
Oil change, engine, with filter
Annually or every 10,000 km
Oil change in rear bevel gears
every two years or every 20,000 km
Checking valve clearance (for maintenance)
every 10,000 km
Changing gearbox oil (for maintenance)
initially after one year, then every two years or every 40,000 km
Replace all spark plugs (for maintenance)
every 20,000 km
Replace air filter cartridge (for maintenance)
every 20,000 km
Visual inspection of hydraulic clutch system
Visually inspecting brake pipes, brake hoses and connections
Checking front brake pads and brake discs for wear
Changing brake fluid, front brakes
Checking rear brake pads and brake disc for wear
Changing brake fluid, rear brakes
Checking freedom of movement of Bowden cables and checking for kinks and chafing
Checking tyre tread depth and tyre pressure
Checking ease of movement of side stand
Checking ease of movement of centre stand
Checking security of threaded fasteners for centre stand
Checking lights and signalling equipment
Function test, engine start suppression
Correcting engine synchronisation (for maintenance)
every 10,000 km
Final inspection and check of roadworthiness
Performing vehicle test with BMW Motorrad diagnostic system
Setting service-due date and service countdown distance
Checking battery charge state
Confirming BMW Service in on-board documentation
Most of these items are just as simple as the description: like charge the battery, 99% of the time you connect the battery charger and it almost immediately indicates a full charge.
Checking the Engine Starting Interlock is as simple as attempting to start the engine in-gear with the clutch out, it should not start.
If you plan on owning the bike I would encourage you to get a GS911 there are many of us with lots of experience using them.
post #3 of 8 (permalink) Old 23-Dec-2016, 07:58 AM (582)
I use an independent mechanic because he does better work than the dealer in my area. You could also do much of the work yourself with the help of the CD-ROM or a Haynes Manual. The stuff you don't want to do have your mechanic of choice complete the job.
Kemo Sabe and rsmith like this.
______________________
Darrel
'16 BMW R1200GSA
'15 BMW R1200GSA - totaled
'13 BMW K1600GT
'08 Suzuki DR650
slowriding is offline
post #4 of 8 (permalink) Old 23-Dec-2016, 03:29 PM (895)
Dr. Strangelove's Avatar
JetSpeed said:
agree.
However, there is a caveat to this. It can be difficult to translate the technical language of the fault codes to layman's terms. The GS911 people have a forum where one can ask questions, but rarely does an answer arrive. AFAIK, there is no "list" of fault codes, their meaning or resolution to be found. I would love to be wrong on the above.
When the GS911 gives a fault code, a short description follows, but nothing else.
examples--I got these 3 doing my 18k svc
80401D Tank switch error
This has something to do with the lock on the keyless gas cap
I did find one query about this one with this response from "Wolfgang"
The electronic immobiliser EWS control unit detects a short circuit of the fuel filler cap switch.
The fault is detected if the fuel filler cap switch is continuously operated with the ignition switched off. The control unit input is switched off after 10 minutes
Check wires, wiring harness and plug connectors to the fuel filler cap switch.
Check plug connector wiring harness to the DME.
Check fuel filler cap switch.
Fault effect and breakdown warning The fuel filler cap can no longer be opened.
80402B Preconditions for locking not fulfilled
This has something to do with locking the handlebars, but that's all I can find.
sometimes the description helps
21F761 Oil-level sensor, level too low
Though, does that mean the oil level itself is low or how the sensor reads is too low--I suspect the former since I ran the diagnostics after draining the oil and before refilling. The engine was obviously NOT running.
these appeared during my 18k service check, I reset them, they have not reappeared.
I have not spoken to a dealer about the codes as they have not reappeared, but I don't know if the codes are proprietary to the GS911 or if those are BMW codes. Admittedly I am still a newbie with it, and don't use it very often, have not had the need except for routine service.
I posted my question about the three faults in early November on their forum, complete with the readout from the GS911. Over 110 "views" and no responses. Does no one know or is no one from hexcode monitoring their "support technical" forum?
That said, I recognize its worth. Just being able to reset the service reminder is a huge plus. This is a nice bit of equipment to have if your budget allows, but better documentation and/or a more active user forum would help a lot. Ignorance ain't bliss.
Dr. Strangelove is offline
post #5 of 8 (permalink) Old 23-Dec-2016, 10:39 PM (194)
Houdini's Avatar
If your bike has no strange issues then servicing the bike yourself is a great option that allows you to spend time with the bike and save money. The GS-911 has more functions than most of us need and it will pay for itself in a few services. A GS-911 and a workshop manual will be your best tools.
If you're not intimately familiar with the service procedures, work with someone else for a few times until you understand the processes.
Dr. Strangelove and =DUKE= like this.
Current: 2013 R1200GS LC
Houdini is offline
post #6 of 8 (permalink) Old 04-Jan-2017, 08:46 AM (615) Thread Starter
I like this approach.....
=DUKE= is offline
post #7 of 8 (permalink) Old 04-Jan-2017, 09:34 AM (649)
The ride of Life
Bumblebee's Avatar
GS-911? Oh, yes - you want one. The GS-911 interfaces with the CAN bus on the motorcycle and communicates with the various controllers on the motorcycle. Resetting the service reminder is just many of the things this can do for you. You can check all of the interlocks (sidestand?) it will do 90% of what the BMW dealers MoDiTech system does. The latest version (required for the LC bikes) has a WiFi radio inside and can communicate with an app in your phone making it truly portable.
It's small and easy to pack, I was able to correct and get a stalled bike running again on the side of the road for a stranded fellow rider.
Two GS-911 kits you can buy, the less expensive one registers VIN numbers, you can have up to ten, after that no more motorcycles can be added without buying more licenses from HexCode (makers of the GS-911). They also make a "professional model" (it's the same thing) that allows unlimited VIN numbers to be added. It's quite a bit more money. They have also added a courtesy mode that allows you to scan and correct a no-strat situation without adding a VIN number. It's functionality is more limited in this mode.
See it here:
The Home of GS-911 ? HEX Code
Anyway, at least one person in your riding posse should have one.
- John
Bumblebee is offline
post #8 of 8 (permalink) Old 06-Jan-2017, 03:09 PM (881)
x7289155's Avatar
do it yourself, there are also dvd's by Jim Vonbarden im not sure of the spelling that is very detailed and nicely taped.
2016 1200GS ADVENTURE WITH ALL THE GOODIES
x7289155 is offline
