Handlebar alignment & mods - BMW R1200GS Forum : R1200 GS Forums
 1Likes
  • 1 Post By JetSpeed
post #1 of 5 (permalink) Old 02-Jan-2017, 12:05 AM (253) Thread Starter
RobinLC
Hi,
Iím hoping someone may be able to help resolve an unusual problem. Back in my younger days I had surgery to stop my left shoulder dis-locating, and as a result the alignment of my left arm is slightly different to the right arm. The surgery was 30 years ago, and itís only in the past year or so this has become a problem. Unfortunately, the activity that causes most grief is long rides on my 2014 GS! The right arm is perfectly comfortable all day, but the left arm is a different story - it wants a different position, with the outside of the hand pointing more toward the ground. As it is, pressure builds on the thumb, wrist, and elbow, and the problem is getting worse.
So far Iíve tried swivelling the handlebars to a different position but this hasnít helped.
Iím wondering whether after market bars might help, but havenít found any available. Or should I try getting the standard handlebar bent, to have the left hand drop toward the ground. Is this possible and how would I go about getting the bar bent?
Any thoughts or suggestions most welcome!
Thanks in advance, Robin
RobinLC is offline
post #2 of 5 (permalink) Old 02-Jan-2017, 06:01 AM (501)
Crowbar's Avatar
Have you tried the adjustable Rox risers..maybe if you shorten the reach with the trouble arm you can find a more comfortable position..then with the quick adjust you can rotate bars on a long ride to find that sweet spot
Crowbar is offline
post #3 of 5 (permalink) Old 02-Jan-2017, 08:35 AM (607)
The ride of Life
Bumblebee's Avatar
Bummer. I'd try risers first. Look at these - maybe helpful?
https://www.helibars.com/products/He...0R-LC/639.html
- John
Bumblebee is offline
post #4 of 5 (permalink) Old 02-Jan-2017, 11:28 AM (727)
To bend the left side to fit your taste you will want to use a 1 1/4" tubing bender, these handlebars bend fairly easy.
The problem is that will have to remove them to make the bend and re-install to check, so it could be a little tedious, just make sure to make small adjustments at a time.
Sed8r likes this.
Fly Navy
post #5 of 5 (permalink) Old 13-Jan-2017, 07:39 PM (069) Thread Starter
RobinLC
Thanks guys, really appreciate the suggestions.
Think I'll start by looking out for a second hand handlebar and play around with that in the garage.
Hadn't thought of risers but that is another option.
Melbourne, Australia
2014 BMW R1200GS
1986 Suzuki Katana 1100
and ...
2007 Vespa 250 GTSie
RobinLC is offline
