Front Engine Cover Removal & Refitting - BMW R1200GS Forum : R1200 GS Forums
Old 03-Feb-2011, 08:06 AM (587)
Default Front Engine Cover Removal & Refitting
Hi Folks,
My front engine cover is badly corroded and in need of re-painting, so I want to take it off and get it powder coated.
Is it an easy job to remove then replace the engine cover for a competent DIY mechanic ? Or is it one of those jobs that never seems to go well from the start, and is best left to the shop to do ?
I have the Haynes Manual, and it gives it a 3 spanner rating, meaning fairly easy for a competent DIY mechanic. My level of mechanicing is fairly good, and I do all my own servicing using the excellent video by Jim VB
Can anybody share some advice, or handy hints & tips to make the job go smoothly ?
By the way I’ve made a two legged puller tool at work to help make the job easier as shown below:-
I also made a crank case oil seal installation tool at work that is shown in the Haynes Manual
Any advice guys ?
Cheers
Andy
Old 03-Feb-2011, 12:54 PM (787)
I'm not aware of anyone who's pulled the front cover due to corrosion. I am aware of folks who cleaned, masked, and painted with a rattle can to good effect. Here's a pictorial of just that:
http://www.advrider.com/forums/showthread.php?t=549035
Yeah, the bike is an R1200ST, but the procedure is pretty much the same.
