Changing the mapping - BMW R1200GS Forum : R1200 GS Forums
Old 07-Feb-2011, 01:54 AM (329)
Default Changing the mapping
I'm just wondering about changing the mapping in my GS. When moving at dead slow speeds in traffic queue and the like, my GS really doesn't like it, probably because it's a twin. I'm just wondering whether the tourers like the RT with similar engines have the same issue. If not, perhaps it's due to the engine mapping and if so, I wonder if it would be possible to put the RT mapping on my GS. Or as has been said before, am I taling rubbish?
Anyone elses thoughts and experiences would be useful.
Old 07-Feb-2011, 04:10 AM (424)
JPB JPB is offline
Thumbs up
Get yourself an "accelerator" from mavn in Belgium. They cost around 25 Euros, take five minutes to fit (or remove!) and will smooth out that on/off effect at low speeds. A search under "acceleator" will produce lots of details and user opinion.
Old 07-Feb-2011, 07:12 AM (550)
What year GS and what is the problem? There is very little info
out there on chip mapping the BMW ECU. The guy in Belgium
makes a "defeat device" which modifies the temperature sensor
and fools the ECU. Mostly positive comments about the device.
Old 07-Feb-2011, 07:24 AM (558)
It's a 06 model, main issue is snatching in very low revs, having read the reviews regarding the accelerator, which just appears to be an plug and play lead, this could be the answer I'm looking for.
Old 07-Feb-2011, 07:33 AM (564)
http://www.mrf.org/pdf/EPA-AI-1.pdf
Be aware (which most people are not) that in the US anyway the use of any defeat device might get a visit from the Feds.
Old 07-Feb-2011, 07:35 AM (566)
These folks appear to be remapping the OEM ECU -
http://www.hilltopmotorcycles.com/index.htm
More information, including some of the pros and cons, in this thread -
http://www.ukgser.com/forums/showthread.php?t=255573
HTH
Old 07-Feb-2011, 07:55 AM (579)
Schtum...I saw this recent discussion and was very interested as
not much info on the subject at least on this planet.
Unfortunately none of the stuff they "talked" about levitated me.
However, not to be a nebob of negatism through the "interceptor" site
I did stumble on to the ANSU fuel injector cleaning and testing machine
which did levitate me.
http://www.youtube.com/watch?v=kX0qFVugxpM
Old 07-Feb-2011, 11:12 AM (717)
At least there does seem to have a tacit admission somewhere in there that we inhabit different planets......
I'd have chunked up to different universes myself but à chacun son goût...
Old 07-Feb-2011, 02:18 PM (846)
The day I see Santa Claus, the Easter Bunney, and the Tooth Fairy in my driveway I'll worry about the EPA showing up at my house. Until then, not so much.
Note that the article in question is talking about the problems of small motorcycle shops and custom cycle builders, not end users. Also, it is arguable that the Accelerator or the Booster plug are defeat devices. They don't defeat or bypass anything. They adjust a value, just like changing the throttle cable adjusters to change your off idle balance. No, I wouldn't want to have to pay for the lawyers to argue that point, though.
Today you can buy different versions of a Y pipe to replace your cat from several vendors. That is obviously a defeat device as it replaces a pollution control device. Funny how the EPA has yet to go after the manufactures or the dealers who sell them, mush less the folks that use them.
Old 07-Feb-2011, 05:32 PM (980)
http://www.epa.gov/compliance/resour...ert/defeat.pdf
Honda 267 million fine. Ford 7.8 million fine. Looks like the EPA rolled
them up and stomped on them on some sort of "defeat mechanism"
issue.
