Battery & Brake Problem - BMW R1200GS Forum : R1200 GS Forums
Old 24-Apr-2011, 02:30 PM (812)
celticbeemer's Avatar
Dont let her sell it.
Default Battery & Brake Problem
Hi All, I have a 2004 1200GS, which has been parked for the winter, now i have 2 problems.
1. The battery was fully drained, and would not take charge, so i bought a new battery, and it started ok, but 3 days later the battery was flat again. does anyone have any suggestions.
2. The Red Warning triangle is on, and my rear brake is very very week, and the noise from the servo is not there, and suggestions.
any and all help is appreciated.
Cheers
Celticbeemer
Cheers
Celticbeemer.
Old 24-Apr-2011, 03:15 PM (844)
1. Did you buy a duff battery? Bung it on an Optimate or similar intelligent charger and see if it recovers.
2 It's likely that your brake problems are down to the flat battery. If the battery voltage drops below a certain level, the electric servos cease to operate.
HTH.....and Slàinte!
Old 25-Apr-2011, 05:09 AM (422)
I thought that initially, but i have another bike with the same battery, and put tit in, and 2-3 days later it was completely flat.
The Servo is working for the front brake, and the front brake is working great, the rear brake is weak and no servo noise.
I have A HEX GS911 Diagnostics tool, and ran a full diagnostics.
Here are the results.
GS-911 Version: 1103.5
AutoScan Report Date: 25/04/2011 Time: 13:03:05
Motorcycle Information
VIN: WB10307A14ZN27713
Mileage: 45314.4 miles
BMS-KBMS type: BMS-K
Part No.: 7697304
Hardware Index: 10
Coding Index: 1
Manufacturer: Bosch
Manufacturing Date: 2004-05-19
MCV: 0.5.6
FSV: 0.77.14
OSV: 2.3.1
No fault codes found
ZFE-HighZFE type: ZFE-High
Part No.: 7699828
Hardware Index: C2
Coding Index: 7
Manufacturer: Loewe Lear
Manufacturing Date: 2003-05-10
MCV: 0.5.7
FSV: 3.0.2
OSV: 3.3.0
Factory I-Level: K024-04-03-500
Actual I-Level: K024-05-11-500
2 fault codes found:
41741 Heated Grips, open-circuit
The fault is currently present.
41722 Park light open-circuit
The fault is not present now.
Integral ABS - CANPart No.: 7680862
HW Version No.: 1
Coding Index: 6
Manufacturer: FTE
Manufacturing Date: 2004-05-24
MCV: 0.5.6
FSV: 1.3.10
OSV: 3.3.0
Assembly No.: 07680862
FTE Serial No.: 52880622X
Hardware No.: 07685812
Hardware star No.: 07680862
ICT barcode: ED3A1D48
Housing barcode
part number: 532222800
Serial number: 12126
Internal index number: 20
FTE serial number
Serial number of device: 168
Modulator: 080
Main computer date: 2003-02-18
Communication and control computer date: 2004-06-18
Communication and control computer version: V03.05
1 fault codes found:
24955 Internal control module error - Analogue value, rear pressure sensor
CAN-Kombi H/LCluster type: CAN-Kombi H/L
Part No.: 7698880
Hardware Index: 1
Coding Index: 3
Manufacturer: Siemens VDO Automotive
Manufacturing Date: 2003-07-24
MCV: 0.5.6
FSV: 1.6.0
OSV: 3.3.10
Assembly No.: 07698881
Cheers
Celticbeemer
Cheers
Celticbeemer.
Old 25-Apr-2011, 11:34 AM (690)
Can you hear the "click" of the brake switch when you depress the brake pedal (engine off, put ear close to pedal)?
How is the fluid level in the rear wheel circuit reservoir? The rear control circuit reservoir?
When was the last time the brakes were bled?
and how are the rear pads?
I don't know if the drained battery is related or not. I suppose it could be an effect if something is really wrong in the ABS unit. The heated grip open circuit is something else I'd look at for a drained battery. Is it open because wires are broken with a power lead shorted to ground?
Old 25-Apr-2011, 01:24 PM (766)
Hi Marc
yes i can hear the micro switch on clicking on an off. if it is the same switch for the rear brake light its working as the brake light is comming on and off ok.
The reservoir is full to the max mark, and the pads where replaced last year, and i have only done about 2k since the replacement. i will bleed the caliper and see if that makes a difference.
The rubber is worn on the grips, so i will order a new set tomorrow, BMW quoted me £50.00 as you just cant buy the rubber grip part. hopefully that may be the issue for the draining battery.
Thanks for the advice, ill try each.
Cheers
Celticbeemer.
Cheers
Celticbeemer.
Old 25-Apr-2011, 01:57 PM (789)
You said "the reservoir". That leads to my next question...
Both of them? Also, it's a long shot but you might want to look at this, too:
http://www.advrider.com/forums/showp...5&postcount=11
Old 28-Apr-2011, 09:19 PM (096)
Marc,
Can you repost the link? I cant get it to pull up.
Celticbeemer,
Have you resolved your issue? What did you do? Did the gs911 clear the fault? I have a similar problem that I am working with no luck so far and looking for all the help I can get.
Thanks,
Sims
2000 DRZ400
2005 R1200GS
Old 29-Apr-2011, 09:35 AM (607)
Don't know what happened there. I fixed the link in the original post.
Old 29-Apr-2011, 10:38 AM (651)
Default Brake & Battery Prolem
Problems are still here, the battery seems to be holding charge for now. i will bleed the brakes over the weekend, and post to let you know if it sorted the issue.
i will follow the fix in the link supplied by marc (thanks marc)
i will update the post asap.
Cheers
Celticbeemer.
Old 05-May-2011, 03:40 PM (861)
Default Batter & Brake Problem
Hello All
I bled the rear brake, but it made no difference, still no servo activating.
I spoke with BMW in Belfast N.Ireland, and the tek hinted towards checking the rear ABS Sensor, after that they would need ot check the bike.
I have been using the bike to clock up some miles to see if use would sort it out, but after 140miles its still not better.
I will clean the Rear ABS Sensor this weekend and report back on the outcome.
I have ordered a new set of BMW heated grips, hopefully that may sort the battery draining issue.
Cheers
Celticbeemer
Cheers
Celticbeemer.
