I always thaught the original top box,32 litres,could have been bigger for when traveling two up,so this is what I did!I used another 45ltr right side case laid on it's side,and built a bracket/box combo underneath so that I could push the box backwards to make it more comfortable for the girlfriend.The box stands just 3/4" higher than the original,but 4"1/2 further back,and was able to have better back rest.The lid now acts has a small table,and it makes it easier for my short girlfriend to access the inside. This setup weighs 8 lbs more than the original top box!
Again to help the the little miss to be more comfy,I made these footrest that I simply bolted to the original passenger footpegs after removing the rubber padding. Then I've install the Fuzeblock FZ1 underneath the seat in the place of the owner's manual,so that I can wire in the extra outlets and bring power to the right side box for my laptop. Last edited by Quanto12; 25-Apr-2011 at 07:15 PM (010). |
![]() For the anti skid,I copied the GS pattern off the the tank the old fashion way,with a paper and pencil, and transfered it to the anti skid tape.Will wear off after a while but it's ok,I can make another! |
Captain, they look like OEM Adventure cases. Mike |
With respect captain, that's one of those "It depends" questions. Or answers anyway. It depends on what you want to do. Travelling around Australia I used the bog standard vario panniers which were fine for most purposes although one did fall off while riding on a long rutted road up the York Peninsula. (Photo attached) I liked the expandable feature but found that the mechanisms jammed up with sand and grit. They were also not 100% waterproof while upside down in a river!
![]() ![]() For my new Triple Black I bought the Touratech-made Zego pro (branded BMW). Here: http://www.touratech.com.au/home/com...244a5ee83d.jpg So far I have been impressed. Of course they are not expandable but they seem sturdy and the fittings operate well. I also use mesh bags inside them so on long trips they mostly stay on the bike. Kennif |
Very very clean.. Well done mate!! Bravo!
If you need some Accessory for your BMW R1200GS: http://www.motorcycleparts-hornig.co...S-Adv-and-HP2/ |
Thanks for the compliments "diethornig"
. I had a real good time doing it too! Can't wait 'till my garage is fully insulated so I can keep doing other stuff!!
