I bought a similar light from an online dealer in china, and could not get it to work.
I could have tail lights or brake lights but not both. I am not technical enough to figure out why, so i might try your solution and see if it works. Delivered to Australia from China, $29 Aus |
Thanks for posting your solution!!!
I have an 07 and just yesterday was at the dealer asking if we could "retro fit" a LED tail light from the new 2011 models that looks cooler and is I'm sure significantly brighter. One of the dealer techs said he was trying to do the same thing on his 07 GS but as of yet could not figure out the electrical "resistor" solution. I am going to call him on Monday and show him your post. If that does the trick, KUDOS to you for your ingenuity Thanks again! |
Be aware that the rear brake and taillight circuit works in one of two methods. Alas, I don't know of any way to tell which method is used on some bikes without dragging a O-scope out to the bike.
Method 1: the brake and tail lights are separate. If there isn't an appropriate current draw the system will throw a LAMP fault. The resistor solution for LED lights will work if your bike uses this method. Method two: the brake and tail lights work together, with the bike using pulsw width modulation (PWM) to vary the effective voltage. Full voltage on both circuits are used for brakes, partial effective voltage on both circuits are used for the tail light function. I suspect that the resistor solution will not help if your bike uses this method, but I'm not 100% sure about that. I'd guess that the newer bikes, say 2007 and later, use method two. LED lights made for use with that system will not work on a bike that uses method 1 regardless of resistors. |
Interesting. I'll look into this more and get back to the forum. I did my testing with a DVM and saw some oddities you would not see in an Analog circuit. When I get some time I'll put a scope on it. I also have access to 07 and 09 GS's as well.
I verified the 05 through 07 use the normal method of turning the tail light and break light elements on separately. I this case the resistor method will work fine. Here is a photo of the end result with clear lenses on the turn signals as well.
I am in a quandry as to which to buy for my 2012 R1200GS!!![]() I don't want to spend a ton of money (The BMW adventure bags are Outrageous)!!!
07' MotoGuzzi Breva 1100, 07' MotoGuzzi Norge 1200, 08'BMW K1200GT/4, 08' H-D Softail Custom, 09' H-D RoadGlide, 2012 BMW R1200GS, 82'Kawasaki GPz750R1 Knees in the Breeze!! ![]()
