Just new 2011, only 40kms on the odo.
1.First thing, I had installed by dealer a hid headlight. When starting the engine, the light comes on, drive off, it goes out with a "lampf" message. Stop, turn off the motor, started it and problem solved. ??? This happened twice. 2.Then on my way back, a yellow warning light with the tire pressure indicator comes on. Stays on no matter what. Pressure ok but no pressure indication on display. 3.Can you trickle charge the battery with the accessory plug? I have a Yuasa battery charger with a red, yellow (charge) and green (storage) lights. The charger does not go on yellow, unless I turn the ignition on and off, then after a minute, the yellow goes out. Is there a timer to that plug? Can I connect directly to battery leads. thanks Bob |
Just to follow up,
Still have to start twice for the HID lights to stay on. Although, when warm, no problems. Must be a ballast issue. At my first checkup, if problem persists will have the unit replaced. The tire pressure sensors were not "paired" with the computer after they changed my rims. Problem solved. |
Actually you can use the accessory socket for trickle charging with a BMW charger. However, the Canbus switches the socket off about 30 seconds after you turn off the ignition, so you have to connect the charger within that time.
It can be used to charge the battery, i'am now using a Optimate 4 dual battery charger purchased from westcobattery.com be sure and order the dual charger along with the correct pigtail. the charger can be plugged in anytime and works with the canbus..
You may want to find out how many watts your HID light is drawing, I believe 55 watts is the maximum for the low beam, then you start getting faults.
2008 R1200GS 2009 F650GS Twin(Wife's) 1987 Husqvarna WR430 |
Supposedly the BMW charger is considered a new generation
"smart" charger and can convince the Can-Bus to allow a "maintenance" charge after the battery is fully charged. This has to do with the temperature sensing ability of the charger. The ZFE (chassis computer) appears to allow some non-BMW chargers to charge through the Can-Bus but kicks them off-line once the battery is charged and does not allow "maintenance" charging. The maintenance charge becomes important as the GS with Sealed AGM battery has a current drain of about 1 per cent per day. People going with "pig tails" and avoiding the Can-Bus do not seem to have any problems. |
I sent you a PM. Mike |
