New guy here, I dropped off my 09-1200gs at the dealer for service (24,000miles) on Monday, let them know that its got a knock/ticking noise on cold starts, but goes away as it warms up. The noise is coming from the left side/cylinder. They did the service but keep the bike over night to do a cold start. They called back and said that's not normal, got approval to replace a chain tension-er under warranty. Well that didn't fix the problem, bike is still at the dealer, they submitted more paper work to BMW to dig into it more. Any clues or thoughts as to what it might be?
Thanks Dave |
Your post describes what is generically referred to as the dreaded
hydraulic lifter click in reference to non-BMW engines. It results from a hydraulic lifter for some reason loosing pressure on cool down and allowing the push rod a very, very small throw until it hits the cam or the lifter on start up with the resultant click, click. Once the engine warms up because of oil pressure and natural expansion it goes away. Its dreaded cause it is a very minor thing except for the short clicking you get on start up. Take all this with a grain of salt as even though I own a 2009 I have never seen a 2009 engine apart or or any clear schematics on how the cam/valve system works. Believe it or not some folks say it is just weather related to a difference in pressures from weather changes especially this time of year. This starts to make some sense when you reflect on the fact that the eco boys insist these engines be sealed up for any venting to the atmosphere. Please keep us posted on what you find.
cat..good heads up. reminded me of a diagram showing the
chain tensioners being loaded by two "pressure valves" (left and right). http://www.bmwmcchattanooga.com/show...ssembly=191929 The interesting thing is only one of them has a internal spring preload. They both appear to be what I would call "hydraulic valves" as they appear to have oil drain holes in them. I would think if the spring were compromised your valve timing on start up would be off and maybe some knocking until the "tensioners" were brought up to pressure. Just a guess. Last edited by pdxrmccgs; 27-May-2011 at 10:39 AM (652). |
The cam chain tensioner issue mentioned by some was an issue on oilheads, corrected with an updated design for the tensioner on the left side. It was never an issue with hexheads. Hexheads had the newly designed tensioner from the start.
That's not to say that a tensioner can't go bad which is probably why the dealer changed the tensioner, first. It's not a total surprise that the change didn't fix the issue. I'm afraid you may have to have to provide the dealer's motivation. Lots of letters, phone calls, requests to talk to the regional BMW rep, etc., might help. |
:::update::: My bike is still in the shop, they are being persistent on pursuing that abnormal knock/ticking noise, gotta give props to San Diego BMW, they got the okay to take off that front black cover on the motor, and to pull the motor out if needed. They are going to look at a tensioner under the black cover (I'm clueless on whats under that cover) first before they decide if they need to pull the motor out of the frame. Will keep yalls posted
Under the black cover is the belt that drives the alternator from a pulley on the nose of the crankshaft. Under those items is the timing case cover. Under the timing case cover are the gears that drive the balance shaft from the crank and under those gears is another timing chain. That chain has a tensioner rail driven by a spring tensioner on the left side of the case.
