Brake - I was changing the tires on my bike yesterday and noticed that the brake rotors have some play in them. The rotors can be moved slightly on a plane parallel to the wheel (not in and out). Is this normal? Both rotors have the same amount of movement and the discs themselves are properly torqued.
Clutch - The clutch fluid level is below the Min mark. In reading the manual it says to use mineral oil, but it is not allowed to pour fluid in! How do I replenish the clutch fluid then? Thanks for any help you can offer. |
My take on the owners manual instruction: You may "add" mineral oil
by pouring some into the clutch fluid reservoir but do not add "hydraulic fluid" which is generally distinguished from mineral oil. Jim Von Baden is very specific on this point in his material in that you do not use brake fluid but mineral oil. The procedure for "clutch bleeding" is usually thought of as bleeding the existing fluid out of the system and replacing with new mineral oil with no air bubbles. At first it is a complex procedure but when the light bulb goes on pretty easy to understand. There are quite a few good posts on the forums on the procedure. The difficulty is making sure there are no air bubbles in the system or your clutch is squishy. Welcome to the forum. |
Minor nit. "Hydraulic fluid" is a generic term that includes mineral oil. It includes any fluid used to control a hydraulic system which could be water. In the particular instance of the BMW clutch the hydraulic fluid happens to be some kind of mineral oil. It used to be the same as Magura Blue Blood used for bicycle braking systems, but I don't if that is still true on later model bikes.
I worked in the mobile and industrial hydraulic industry for several years
and the only "stuff" we used to power pumps valves and cylinders was called "hydraulic fluid". It was several years later that I heard the term "mineral oil" in a engine break-in discussion and I asked and have asked for many years what is mineral oil? The normal feedback I get is something about natural oil...no additives etc. So...I have asked anyone who seems interested and knowledgeable: If Abdul pulls a bucket of water up for his camel Husef from a oasis well 10 miles from a Shell complex in the Saudi Arabian desert and finds oil floating on the top...is that mineral oil? Most peoples response is something to the effect that maybe I should consider counseling and walk away as fast as they can.
| Tags |
| clutch, fluid, movement, play, rotor |
| Thread Tools | |
| Display Modes | |
