I have not had to bleed the brakes on my 09 GS but if and when
I do I am going to take a hard look at the bottom up "Mityvac" series of products. In theory the "4 hands" red neck procedure should work but that is in theory.
A Mightyvac can damage the servo ABS unit according to BMW (but I've never read of it happening).
You can't ride without a back brake because your bike has a linked braking system. When you pull the hand lever BOTH brakes are operated. When you step of the foot lever only the back brake is operated. Servo bleed is not hard, just time consuming. The tank has to come off to get access to the servo unit. Full instructions in excruciating detail are at http://advwisdom.hogranch.com/Wisdom/service_abs3.pdf http://advwisdom.hogranch.com/Wisdom...ng_adapter.pdf ABS 3 is what folks called iABS (the servo system) when it first came out. Don't let the fact that the instructions are for an oilhead bother you. The servo brakes are the same on the early hexheads. Lastly the above docs talk about bleeding the control circuits 4 times from three bleed points for both the front and the rear circuits. BMW made that easier... you only need to bleed from the "tall" bleed unit on the ABS unit. Here I'm bleeding the rear control circuit... ![]() My 60K service including brake bleeds... http://www.snafu.org/pics/r1200gs/2011/0122-service/ Last edited by marc; 08-Jun-2011 at 11:03 PM (169). |
That seems to be odd and probably not related to the brake pad wear, unless the pucks were so far out of the calipers that the oil in the servo unit was low. The odd thing is that both master cylinder reserviors were full and aren't lowering any. That seems odd too.
If you want to minimise rear pad wear, clean the brake dust out of the holes on the rear disc at regular intervals. One of the techs at my local Motorrad dealership told me that the build up of brake dust in these increases pad wear.
