I purchased this bike used from the dealer in Tucson. Love it! However, after 6K miles I did my first Oil change only to discover the Skid Plate was apparently ripped from the bike at some point. Now that its time for rear brakes, this is what i discovered! The Radial Center Line of the Pads is NOT the same Radial Center Line of the Rotor.
There is apparently no adjustment for this, the Calipers remove and replace with no binding, but, after replacing the Pads, and 300 miles, the wheel feels very tight to turn. Plus, during slow speeds I think I can hear brake noise. The reason for mentioning buying the bike used, I'm starting to suspect accident damage. Your thoughts?
Sandy Cleland Huntsville, Al & Tucson AZ 07 R1200GS - 24K miles 98 K1200RS - 12K miles 98 Roadstar - 81K miles 07 KLR - 8K miles |
Not sure how that could even be possible. None the less, here is an additional photo from the front to show the bolts are in place, everything else appears to be normal.
Sandy Cleland Huntsville, Al & Tucson AZ 07 R1200GS - 24K miles 98 K1200RS - 12K miles 98 Roadstar - 81K miles 07 KLR - 8K miles Last edited by ezeflier; 05-Jul-2011 at 03:41 PM (862). Reason: forgot photo |
just one question, how'd you come up with a photo of that particular part so quickly!???
www.snafu.org/pics/r1200gs/ is my "r1200gs" blog. I've documented most of the farkles I added to the bike. For the last 3 or 4 years or so I started documenting maintenance, too. That picture came from my 60K service when I did a full brake bleed and rear caliper cleaning.
Not everything is on the web page. My photo archive currently contains about 1100 images tagged GS. That included pictures taken on various rides that happen to include the GS. I've about 2200 images tagged R69S. I've had that bike much longer. Edit: what I looked for but didn't find was a picture from the bike's left side with the wheel off and the caliper on. Apparently I've never taken one of those. |
