LED Flashing Rear Tail Lamp Fault - BMW R1200GS Forum : R1200 GS Forums
Old 16-Aug-2011, 08:55 AM (579)
Question LED Flashing Rear Tail Lamp Fault
Anyone experience any lamp fault with a RoadRocketeer LED flashing tail lamp unit.
It comes and goes while riding. More braking seems to trigger a fault code.
Will reset after shutdown and restart. However, there is is occasion for the fault code to appears while riding: eek: and then disappear without complete shutdown. Only to reappear later.
Confusing!
Cannot figure out how to face this problem.
Phil in San Leandro
Old 16-Aug-2011, 11:41 AM (695)
Check where the tail lamp plugs into the socket. A loose socket or one with a bit of corrosion can cause the kind of issue you are seeing. A shot of contact cleaner might help.
Or it might be something with the tail light unit. Good luck if that is the case.
Old 17-Aug-2011, 09:01 AM (584)
ca1ic0cat's Avatar
Default I had to clean the center contact on mine
I was having taillight problems with the stock bulb. I cleaned up the copper contact with some steel wool and then put a blob of solder on the copper to help with contact to the lamp. Haven't had any trouble since.
Old 17-Aug-2011, 11:20 AM (680)
Thanks.
I'll check these when I get home in a few days.
Phil
