Back to the future....
Here is a link to a discussion where at least one person says get rid of the Gel Cell's as they are to temperamental and retro to the older (trouble free) wet lead acid batteries. The hard ridden GS of course will have more "nap" times with the potential for spillage...the posters say just deal with it. Interesting. Motorcycle battery bad? Plenty of cold cranking amps but won't hold a charge.? - Yahoo! Answers |
Thanks for that - an interesting discussion although ultimately inconclusive. I don't think the problem can be my battery - otherwise, why would it fire up so readily when we made a direct connect from the battery to the starter motor.
If it is a fault between the starter button and the starter motor, why are we getting current at the starter motor when I press the button. Why won't the damn thing go?!!!!! (That was a rhetorical question - I don't expect anyone on this forum to know the answer.) |
I keep coming back to idea that it is the starter relay, or associated wiring.
The wiring diagrams are here (if you haven't found them already): http://www.r1200gs.info/R1200GS-WD2.pdf I'll print them out (it's hard for me to read them on a screen), and look through the service manual to see if there are any inspection instructions for the starting system (doubtful). I'll keep checking in to see if you need help reading the diagrams or locating the relays. I'm sorry I don't know more about BMW. If it was a Concours, I could walk you through the whole process... John |
Hello,
I'm new here but had a similar problem today on 08 R1200GS. I connected a GS911 and confirmed that all switches and sensors are oprating (kill switch, starter switch, sidestand...) The BMS-K senses the starter switch but voltage won't show up at the solenoid spade terminal. I can start the bike by directly feeding tge spade terminal of the solenoid with 12V. After looking at the wiring diagram I went searching for the starter relay under the tool tray but it's no longer there. Seems that from 08 onwards got relocated under the tank. As far as I can tell the relay isn't working. After replacing I'll update here. Regarding the OP prob, I would bet on the relay also. How did the AA man concluded that you have 12 V at the starter when you press the starter button? 12 v are always at the solenoid power input (at the big upper threaded terminal) . What should be fed with 12 V when you press the button is the spade terminal just alongside. |
Forum discussions and I believe the owners manual point out that the
ECU has a nasty little bit of software that prohibits or defeats the start process unless the ecu is satisfied that the engine as soon as it is started has available to it from the battery enough voltage and current to run and satisfy the eco/emmissions requirements imposed by the various federal certifying agencies on start-up and before the alternator starts producing. For starters (no pun intended) your battery should show 12.6 to 12.9 volts plus load test to no less than @10 volts. |
They found a used starter somewhere, put it on, and the bike ran fine. I don't know, but ??????? Good luck. |
Just purchased the 09 R1200GS in August of 2012. The bike has started first time every time in the nearly 4,000 miles I've ridden since. That is until yesterday after one of our stops it would not engage the starter, checks run fine with no faults on the dash when ignition turned on. Did all the obvious - flip kill switch back and forth, engage gear and return to neutral attempt starting with clutch pulled in all to no avail. Then it just started when I pushed the starter switch. At the next stop I was nervous about turning the bike off but since it looked like we would be waiting a while for one in the group to catch up I did. After about 15 minutes we were ready to ride but again my bike would not start. This time I put my ear near the tank and heard a faint click each time I pushed the starter (starter relay?) that I didn't hear with the kill switch turned on. Checking the battery connections found the ground lug slightly loose. Thightened but still no start then for no good reason it started. My battery was replaced in May 2011 with a Interstate YTX14 from records of previous owner. The voltage at rest is 13.15 and at idle 14.58 I made a jumper to "hot wire" the starter in case this happens again but started fine this morning. Is there a list of other things I should check if this problem returns?
