Can anyone guide me on how to replace the brake fluid of my 05 R1200GS? I know a thread exists for the 1150GS but I am not sure whether brake systems are the same. If another thread exists I'd appreciate if someone would highlight such a thread for me. Many thanks.
Pulled from the MOA site.
Is the '05 an ABS machine? If so then it has the electro-assisted brakes and you'll need some tools to bleed the wheel circuits. Tools needed: http://advwisdom.hogranch.com/Wisdom...ng_adapter.pdf Procedure: http://advwisdom.hogranch.com/Wisdom/service_abs3.pdf What those documents call "ABS-3" is called iABS by BMW and was in use from '02 through '06 (or was it '07?). The current brakes are iABS II.
Rick '08 R1200GS '99 K1200RS (the fast one) |
I just bought a great official manual on DVD for $10.
From this guy: |
There are instructions at the first link in the second post in this thread. (BMW will not sell the tool.)
I made mine a little differently. I drilled and tapped one of the filler caps and threaded a small pipe nipple into it and attached the nipple to a small funnel. Then I put a plug (same threads) in the hole after using the funnel as a temporary reservior for bleeding. Works fine. The DVD manual I mentioned above has pefect instructions for bleeding. If you buy that disk, spend some time studying it. The photos and drawings all expand if you click on them. It's really good. |
