Installing AdMore Rear Tail/Brakelight Module - BMW R1200GS Forum : R1200 GS Forums
Old 26-Oct-2011, 02:39 PM (818)
Default Installing AdMore Rear Tail/Brakelight Module
I recently bought an auxillary rear brake/tail light module through Twisted Throttle made by AdMore Lighting in Canada.
The instructions simply state to connect the six multi colored wires from the AdMore unit to these left/right turn-signals, tail/brake light wires etc...vague to say the least.
Has anyone on this forum installed this set-up and/or had any issues with it?
Thanks...
Old 19-Nov-2011, 03:23 PM (891)
Talking
I have installed the Admore kits in both a Givi 52 case and recently on my GS 1200 top case. Both were fairly simple. Make sure to use the right size posi-tap for the wires you are tapping into. The GS uses very small wires so a small posi tap is required.
Unwrap the taillight wires very carefully and locate the proper wires. Going to the turn signals will be a positive and a negative wire. Use the positive wire. You can find these using a test light with a sharp point. Use the test light to locate the brake light and tail light. Hook the other wires into the taillight and brake light wires. One wire will go to a ground.
You will like your new lights.
Old 17-Mar-2012, 10:50 AM (659)
Default Admore Lights
I appreciate your reply and feedback sir. Thank you.
Now if I can only find the lame instruction sheet that came with the Admore's, I can figure out which color coded wire goes where...LOL.
Kent (aka beemerbum)
