Has anyone fitted these Cree spotlamps, the state they need no additional switches and come on with the ignition when connected to the battery:
BikeVis Store | Cree LED Running Lights |
I looked at the website. It mentions wiring ina control box. Although it does not spell it out, I suspect it monitors the voltage or ampage.
I would rather skip the control box then: a) wire the lights to a switched circuit with the key b) a seprate switch and wire to the battery c) or, wire it to a switched circuit with key and a switch. The instructions did break out which wire does what. In the worse case you could wire with a switched circuit and the control box.
2001 Harley Sportster 1200 XLH Jade Green Gone: 2006 BMW R1200RT Peidmont Red Gone: 2008 F800ST (L) Blue 2005 R1200GS White |
