Why does clutch play vary? - BMW R1200GS Forum : R1200 GS Forums
Old 03-Jan-2012, 01:29 PM (811)
Default Why does clutch play vary?
I have about 1" of clutch play at the end of the lever when riding and all of a sudden, it's 1/2" of play. What happens to cause this? It's disconcerting.
Bill
Old 03-Jan-2012, 04:37 PM (942)
Guess: you've got problems with your slave cylinder. There was a recall on re-routing the clutch line for some production year GS. Don't remember which one. Others have had slave cylinder issues. In any case it is not a good thing. A leaky slave cylinder, for example, can contaminate the clutch.
Old 21-Jan-2012, 04:44 AM (447)
Default Maintenance and Modifications
I believe Marc is entirely correct with his assessment. There was a service bulletin on rerouting the clutch line on the 2009 model year. My bike had the modification and, not long after that, the slave cylinder bid me farewell. Naturally, I was in a remote part of southern New Mexico when it happened. I got it "patched up" after a 600+ mile ride in a wrecker. By the time I got home, it was failing again. My regular dealer ended up replacing the slave, master cylinder and the line.
Please have this checked out.
Mike
