I have the vario on my 2011GS if the alloy boxes mount different than the vario I would go with them. Seems their are some instances where the vario boxes can depart the bike at speed or rough roads. I have installed the BMW enduro kit to prevent this from occurring $30 US from dealer, ouch, 2 screws 2 nuts 2spacers and a couple of washers and a nice 60 page installion manual in six languages.
Look up the installion guide on line you can duplicate the parts for a couple dollars at your local hardware store You will still want to key your case to your new bike will your dealer do it for free? |
I'd go with the alluminium top box, much stronger set up all together! I had the vario top box fall off after hitting a pot hole on the highway!
I did like the expandable system on the vario giving it an extra capacity, about 13 litre more than the alluminium top box! That's why I modified a right (side) alluminium side box into a top box for when I plan a long ride with the girlfriend! |
Thanks a lot! |
I found out about the enduro kit from a blog, went to long beach BMW and asked for the top case enduro kit, Called Topcase enduro lock for R1200GS,
Kinda over priced Open your top box you will see two rubber grommets towards the back of the box, if you will remove these the holes line up with with the holes in the black steel support bracket under the attaching plate, remove the rubber grommets from steel support, now drill through support plate, silver plastic part. Case holes will line up with support bracket holes I used a 7mm drill. Parts needed 2 M6 screws 1-1/4 2 m6 self locking nuts 18 m6 washers or 6 washers and 2 3/8 spacers Screw goes though case with 1 washer inside of case 3washers between case and adpator plate, between adapter plate and black steel support bracket,you removed this grommet also goes the 2/8 spacer, bottom of steel support another washer and self locking nut. Once you remove the grommets in case install case on bike you will see how it works At most $2 dollars in parts |
Great tip! Thank you! |
I did something similar, but I used rubber faucet washers between top box and base.
Eventually, the Vario vibrated itself into failure, with a split in the ABS all around the lock recess. I replaced it with a SW Motec Trax aluminium top box at 2/3 of the OEM top box price. |
