CANbus Helper - BMW R1200GS Forum : R1200 GS Forums
Old 05-Mar-2008, 11:53 AM (745)
nw_gser's Avatar
GS Rider
Send a message via Skype™ to nw_gser
Default CANbus Helper
Have any of you installed these Touratech CANbus parts to run accessories?
TPS 15 CAN Bus Output Helper
SSR-01 Voltage Control Module
My new Adventure is scheduled to arrive in the US on the 10th and take a couple weeks to get it out here in Seattle. I never got around to install any accessories on my old Adventure, was too busy riding it. I plan on buying all the stuff I need prior to delivery.
Old 05-Mar-2008, 03:06 PM (879)
kurt1305's Avatar
I have the Canbus helper. It works well, the only down side is you have to remove the tank to access it.
Kurt
2012 R1200 GS Adventure
Old 05-Mar-2008, 04:35 PM (941)
nw_gser's Avatar
GS Rider
This is the reason I would like to install the Touratech version instead of the others which seem to only have one spot to install, the tool kit space.
Old 08-Mar-2008, 07:16 PM (053)
gwdavis's Avatar
Default Tps15
Iinstalled TPS 15 AS so. Works for me.
Check here
Where did you mount your Centech AP1 ?
Old 09-Mar-2008, 05:03 PM (919)
gwdavis's Avatar
Or this may work as well
http://www.r1200gs.info/forum/attach...3&d=1199990383
Old 16-Mar-2008, 03:13 AM (342)
TKE TKE is offline
Rider
Put mine where the tool kit was instead of under the tank for better access and it is great.
Old 01-Apr-2008, 04:44 PM (905)
nw_gser's Avatar
GS Rider
Did you notice the big space hidden under the tool tray?
It is not a waterproof area but a good place to stash items.
I rolled up the pathetic tool kit that came with the machine and stuffed it in that space.
