I'm looking for a fuse block for my GS, before I start with the electrical farkles.
![]() The dealer already re-wired the underseat powerlet directly the battery, but I like the clean look of having only one accessory connection direct to the battery. I'm planning on adding auxiliary lights, and a GPS, at minimum. Paul Wilson Washington, DC 09 R1200GS |
One solution: http://www.snafu.org/pics/r1200gs/2009/0204-fuzebox/
Wiring up the trigger wire is explained at http://www.snafu.org/pics/r1200gs/wiring/ when I first used the method to trigger the relay on some aux lights. |
