rear splash guards - BMW R1200GS Forum : R1200 GS Forums
Old 21-Feb-2010, 11:58 AM (748)
Default rear splash guards
i have an'08 r12gs w/happy trail panniers, the pannier brackets the way they are, clamp onto the frame right where the mudsling or maier splash guard would mount. i would like something to protect the shock and battery, i've looked around and haven't come up with anything.....any ideas?
Old 21-Feb-2010, 12:49 PM (784)
Fit a hugger..?
Old 21-Feb-2010, 04:17 PM (928)
The battery is protected by a thick case. For the shock you can fit a shock sock.
Old 21-Feb-2010, 07:27 PM (060)
thanks guy. i will look into shock sock, but i would still like to have something to keep my legs dry too. but something like a mudsling would be nice because i still get mud and water up under my seat where my tool pouch is
Old 22-Feb-2010, 09:20 AM (639)
Bullwinkle's Avatar
Fossilized Member
Default Here's an alternative
Here's a very cheap but effective alternative to huggers and mudslings, and a few other ideas as well...
Rear fender fix
Old 22-Feb-2010, 01:46 PM (824)
hey thanks for the info. that looks like a damn good solution to me
Old 01-Mar-2010, 02:28 AM (352)
Default Rear splash guard
Check Nippy Norman, they have an exelent mudsling which protect the shock damper and aginst dirt below the sadle and battery.
Old 16-Mar-2010, 09:45 AM (614)
Krakken's Avatar
Default MudSling
I had the same problem when I mounted my Jesse bags; the mounts clamp in the same location as where the MudSling would rest against the frame. I used a Dremel tool and cut out a notch in the MudSling so it would nestle in nicely around the clamp. Took only minutes to cut, fits tight, and you don't even notice the notch unless you look for it.
