Hi everybody.
I finaly decided to connect my Touratech lights. I prepared the wire to be installed. Touratech is a bit strange since they sent me two set of cables including two relay. I don't really know if it's a plus but I designed the schema to use both. The switch signal is going to both relay (Still don't know for sure if it's going to commute both relay). My question is: Which powered cable can I use to activate/deactivate the relay since I don't want to use the low beam power (I want to be able to turn on the fog light at wish regardless if the low beam is on or off). Thank for your advices. Alex |
Of course ignition on only.
![]() I don't want people to play around with my lights when I'm away. :P I was considering the parking light but found the wire very thin. Thank for mentioning someone did a harness/extension. I always hate to do irreversible modifications. It's the way I am. ![]() Thank again. |
Hi everybody.
Today I managed to find enough time to finish the mount of the aux lights. As for the signal source, I connected it as mentioned previously on the parking light wire (blue/white). This is working perfectly. I'm waiting for the GS A aux light switch so I can have a "in design" switch to use with my beloved. Regards Alex |
Alex - were the Touratech lights you installed the HID driving lights or the fog lights? It sticks in my mind that the HID lights require the dual harness set-up.
"If guns cause crime, then all of mine are defective." Ted Nugent 2007 BMW R1200GS 2009 KTM 300XC-W |
