Helmet Lock ? - BMW R1200GS Forum : R1200 GS Forums
Old 09-Oct-2010, 03:31 PM (854)
Default Helmet Lock ?
Hi All,
Just got my 2010 R1200 GS today and see that I need a helmet lock what is the best one on the market ?
Thanks for any help you can give me.
Scott
Old 09-Oct-2010, 07:35 PM (024)
RCH RCH is online now
I bought a helmet lock from dealer for previous year and mounted it.
BMW part number
51252313472
Looks like the cost is $37 and change plus the cost of lock cylinder.
You will need to buy the lock cylinder, the dealer can key it for your key.
See red arrow just under seat on 2008 R1200GS
Name:  Lft W Can and Bag2.jpg
2008 R1200GS
2009 F650GS Twin(Wife's)
1987 Husqvarna WR430
Old 10-Oct-2010, 02:57 PM (831)
Default lOCK
Thanks for the info !
Did you put the lock on your self ? Did it fit ok ?
Does it come with a key or did you have it re-keyed at the shop ?
Thanks Scott
Old 10-Oct-2010, 03:34 PM (857)
You have to buy the lock cylinder separate, but the dealer will key it for you. I installed it myself.
2008 R1200GS
Old 22-Oct-2010, 04:38 AM (401)
Does it bolt right on or do you have to make a clamp ?
Thanks Scott
Old 22-Oct-2010, 10:08 AM (630)
There is a brace that has two holes in it that are almost a perfect fit for mounting the lock. You will need to open up one of the holes to take an M6 screw and you will need a lock nut for the back side.
Regards,
Richard
2008 R1200GS
Old 22-Oct-2010, 04:53 PM (912)
Default Reply
Regards,
Richard
Thank you for your help Richard !
Scott
Old 22-Oct-2010, 05:07 PM (921)
Good Luck with your project Scott. I put one on mine because I got tired of my helmet falling off my motorbike, got tired of having to take the front seat off to lock my helmet.
Regards,
Richard
2008 R1200GS
Old 25-Oct-2010, 07:47 PM (032)
jphrse's Avatar
Has anybody tried one of these on a GS? And if so what is your opinion.
Even if you have not used or seen these before which one do you might think might be better. I need the ability to lock up two helmets.
http://www.ascycles.com/detail.aspx?ID=1622
http://ascycles.com/detail.aspx?ID=1621
2007 R1200GS
