Replacement Windscreen - BMW R1200GS Forum : R1200 GS Forums
Old 03-May-2007, 12:22 PM (723)
Default Replacement Windscreen
My first post. Hello and thanks for your help. I use my GS mostly on long trips to areas where I then go off-road, so the majority of time is spent riding at speed on the road. The stock windscreen causes buffeting. I am 5' 10" tall and use a Schuberth C2 helmet. The C2 is quiet, but the buffeting tends to negate the positive affects of this fine helmet. Is there consensous amongst you as to which aftermarket windscreen best negates this affect but doesn't look lke something I made in shop class?
Old 03-May-2007, 02:14 PM (801)
Hi Peebster...problem with a tall fixed screen is that it's not a good solution for when you do finally go off road...the ideal solution is a variable screen such as the wunderlich vario screen or the Touratech desierto III...
Can't say that I care much for the looks of the wunderlich screen and whilst the desierto III looks great...it's pricey...
others will probably have alternative solutions.
Desierto III Pics...
Old 03-May-2007, 02:48 PM (825)
I believe that the current hot tip is the Givi screen + the GSA winglets. I'm currently running the standard screen + Laminar Lip + Adventure winglets but that might be too "made in shop class" for your tastes.
Old 03-May-2007, 03:32 PM (856)
Middle aged hooligan
I have the adventure winglets, which definitely help the buffeting. I tried the CeeBaileys +2"+2" screen and noticed a further, albeit minor, improvement in buffeting, but not in wind noise.. I have since switched back to the stock shield (+winglets). I'm going to try it on a reasonably long trip this weekend and will let you know how it works out.
Steve
'07 R12GS
'03 K12GT
Old 03-May-2007, 06:47 PM (991)
Default Less is more
Instead of more screen, try less. A dremel tool or a band saw works wonder it cutting down the stock screen which then puts clean air around your head. The windglets might be a nice addition, but preclude the use of tank panniers which I couldn't live without.
http://www.snafu.org/pics/r1200gs/windscreen/
Old 04-May-2007, 08:30 AM (562)
Thanks. The "less is more" idea warrants a try. When I ride my son's Dakar, the lack of wind protection creates clear air (pretty much) in the face, and the C2 handles that pretty well. I think I will remove the stock windscreen first, do some highway riding and see if that works. Much cheaper than buying something without testing.
Regards.
Peebster
Old 04-May-2007, 03:49 PM (867)
JimVonBaden's Avatar
Kool Aide Dispenser
Send a message via AIM to JimVonBaden Send a message via MSN to JimVonBaden
That's what I use for cold weather riding.
Then I switch to the TT dash cover for summer.
It has much smoother air than my cut-down screen had.
Jim
Click here for the R1200 Maintenance and Accessories Videos for sale!
R1200GS with a few accessories!
