It all adds up - 110W for dip+main beam, 200W for driving lamps, brake and tail lamps, turn signals, instrument lamps, heated grips, ignition system and possibly the brake servo. With all that switched on at one time it could become marginal, especially at low revs and with an older battery. Better, as you suggest to go the HID route.
