auxiliary power distributor - BMW R1200GS Forum : R1200 GS Forums
Old 19-Dec-2010, 01:58 PM (832)
Default auxiliary power distributor
i need one of those gadgets that distributes power from a fused module.
the only one i have heard of is the "centech" unit.
i did not want to order if there is something cheaper or better out there.
it will go on my 07 GSA.
thanks in advance for your input.
Old 19-Dec-2010, 03:20 PM (889)
R120oGS Hooligan
I went with centech II. So one side switched one not. There is also eastern beaver, and another whose name escapes me. All have pros and cons. I think the cost varied as well but not radically.
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
1986 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Old 19-Dec-2010, 04:30 PM (937)
Fuzeblock. Small, built in relay, but a limit of 10 amps/circuit, 30 amps total.
My install: http://www.snafu.org/pics/r1200gs/2009/0204-fuzebox/
Old 20-Dec-2010, 05:57 AM (498)
This one looks interesting, but I don't know anything about it other than the link info.
http://www.aerostich.com/powerpak-po...ule-pdm60.html
Old 22-Dec-2010, 12:29 PM (770)
the aerostitch unit looks like the hot setup, but a little pricey.
i think i'm gonna go with the centec II .
thanks for your responses.
Old 23-Dec-2010, 06:27 AM (518)
I went with this one:
http://excelcyclewerkes.com/index_files/Page672.htm
This guy Tom manufactures the bracket and builds out the custom harness for your specific application. On the GS it positions the Centech panel forward against the airbox which both frees up the tool kit area and makes for a cleaner install as most wires will be coming from forward of that.
Best part is the "wow, this is a nice piece of engineering" I felt when I took it out of the box. Makes for a very professional install.
Old 23-Dec-2010, 04:15 PM (927)
Touratech makes a CanBus friendly distribution device - relay and fuse protected for around $30 that will isolate your goodies from the CanBus and does not require a fusible link that the other distribution panels should have.
http://www.youtube.com/watch?v=MEn2wUVLKD4
Marty H
