The Odyssey is popular. It's not my choice as it's advantages (it is a deep discharge battery) aren't applicable to my use. Any YTX14-BS or YTX14H-BS battery will be a drop in replacement, but watch out where they are made. The $35 dollar batteries are not very good.
Last change I put this in my bike: http://www.batterystuff.com/batterie...YTX14H-BS.html The 'H' version has a tiny bit more CCA than the standard version. Or you can be part of the leading edge and try one of the Shorai Power LiFe batteries. Smaller and maybe 1/4 the weight, but expensive. Those who have used them report better starting than the stock battery. http://www.shoraipower.com/SearchBat...hterm=ytx14-bs Except that they are out of stock. Everyplace, I think. Apparently the newer version was going to have stronger battery posts and then a little earthquake and tsunami that you may have heard about happened. Rumor says they'll be back in stock in May.Next time I have to change batteries I'll be looking at the Shorai battery. |
I went with the odessey. GMan Industries sells a pre modded one. Their website states premodded by them will not void the warranty.
Then all you need is a new strap. That said I did the cross bar mod as well just for my own piece of mind. So far so good. We'll see how it stands up long term. It was no more expensive than some no cheaper either. I think it was $120 which is (in my mind) cheap for a higher end battery vs say Yuasa.
01/09 DRZ470SSW more bits than necesary 2005 R1200 GS AKA The Mothership 2003 Z1000 Nuclear Pumpkin (gone) 1986 RG500WW (gone) Bikes are like women. What you think you want, and what you want, change after the first ride. |
07' MotoGuzzi Breva 1100, 07' MotoGuzzi Norge 1200, 08'BMW K1200GT/4, 08' H-D Softail Custom, 09' H-D RoadGlide, 2012 BMW R1200GS, 82'Kawasaki GPz750R1 Knees in the Breeze!! ![]()
