Latching vario bags - BMW R1200GS Forum : R1200 GS Forums
Old 03-Nov-2011, 07:10 PM (007)
texascat's Avatar
Texascat
Default Latching vario bags
Hi gang, need some help.
I just received a set of vario bags and when I try to latch them I cannot push down the red tab over the mushroom latch to close. The maller red tab by the handle is lifted up. Mushroom is at 27 mm as per information found on this forum. Is there a specific set of steps to follow?
Your help appreciated
2011 BMW GS
Old 03-Nov-2011, 09:11 PM (091)
27mm is the starting point. From there you adjust to get a snug fit.
Old 04-Nov-2011, 06:43 AM (488)
When you set the bag on the bike make sure it sets down all the way into the inserts where the bag hooks to the rail, latch the forward latch and then attempt to latch the upper lock by pressing it down it will not lock all the way down and stay down, it will be a little loose until you push the small red handle down. If it won't latch back the locking knob out a turn and try again. After you find a point where it will latch, fine tune it to get your best latching action. You will have to re-rig the latch system over the years as the parts wear. The inserts where the bags sit are designed to wear and are replaceable.
Rick
'08 R1200GS
'99 K1200RS (the fast one)
Old 04-Nov-2011, 07:08 AM (506)
texascat's Avatar
Texascat
well, I played with the mushroom screw up and a few mm, and it worked when I was about 28MM. I did not they were so 'sensitive to +/- 1-2MM, but they do fit snug.
Not is still has a little resistance when I press down the larger red tab, but I assume that is normal (I hear a click).
Thanks for the insights... and i did also find the instructions in the owners manual. Did not realize they were there
2011 BMW GS
Old 04-Nov-2011, 08:49 AM (575)
Correct they are height sensitive takes quite a bit of pushing on mine to get them to snap on, I have on occasion used the handle end of a hammer to assist in pushing down the red latch a little silicone lube on mushroom bolt also helps
2011 1200gs
Old 05-Nov-2011, 07:47 AM (533)
Looks like we are done here.
Rick
'08 R1200GS
