Problem with replacing the bash plate. - BMW R1200GS Forum : R1200 GS Forums
Old 05-Aug-2007, 03:21 AM (347)
Jason W's Avatar
2004 Yellow R12GS
Default Problem with replacing the bash plate.
Anyone out there able to tell me how to remove the two rear rubber-block mounted bolts to fit the Touratech bash plate I've just bought?
The instructions say to just remove them but to take care not to shear them off whilst trying to do so.
I've tried a deep drive socket, a ring spanner, even small stillsons, but they just want to twist.
Anymore force applied will surely shear the rubber, rendering me unable to re-install the original plate or fit the new item.
Old 19-Aug-2007, 12:47 AM (241)
Default Bash Plate
You just need to use a little force. Yes, the rubber will twist but unless someone has overtightened the nuts you should not have any problems. You need a 13mm socket and perhaps some WD40 if necessary. Hope that helps.
Regards Roger
Old 27-Sep-2007, 05:43 AM (447)
Billy Bones's Avatar
F650GS, R1200GS
Default bash plate
Jason Ive taken mine off, it does require some twisting there is a small piece of metal on the top of the rubber plugs. I did rip all mine in half trying to get them off.............I worried
