Folks, I've been struggling to find a proper (as in working all the time) air compressor for my 1200GS. There are many sites out there selling mini compressors, some of them have reviews that would make you run the other way. I don't want to carry a normal 12v compressor with me when I go touring, although I probably could make some space.
These are the sites I looked at: MOTOAUS.COM - Stopngo 12v Portable Motorcycle Air Compressor | Reviews | products Buy Now: Cycle Pump Motorcycle Air Compressor, EZ Air Tire Gauge, Tire Repair Kit | Pashnit Moto Slime Air Compressor vs. AirMan Sparrow Air Compressor - webBikeWorld Stop & Go 12V Mini Air Compressor for Motorcycles - Touratech-USA MINI AIR COMPRESSOR 12V MOTORCYCLE SCOOTER ATV PRESSURE GUAGE | Gadget City | Lasoo Online Catalogues Can anyone recommend a reliable 12v mini compressor? That would be great. Thanks in advance |
Yeah, I can see that. I was desperately hoping I could let someone else do the hard yards rather than getting sweaty over 4 missing PSIs. How long would you need to be a slave to the pump to get 1 PSI ? Thanks folks for your replies. |
I've never timed it. Please keep in mind that it's a low volume pump meant for emergency use. It's taken two or three minutes to pump a flat tire up to around 35 lbs, or 2.4 bars. I've used it occasionally, when traveling, to put a little air in so my best guess would be thirty seconds for pound of air. Mike |
I've tried taking the casing off cheap auto parts store compressors (twice). Both eventually broke. Cycle Pump is the way to go, and you'll probably never need another pump again.
BTW I replaced the chuck with a thumb-lock because of issues with my old ST1300's valve stems. Last edited by Twempie; 30-Oct-2012 at 04:14 PM (885). |
