I Just Recently Bought A Led Tail Light For My R1200gsa And Installed It . It Works But On My Instrument Panel I Get A Warning That One Of May Tail Lights Is Out. Does Any One Know How To Turn The Warning Off. Ifnot Does Any One Know If They Will Be Making A Software Update To Fix The Problem?
The LED's you have installed I assume are the straight replacement type you might put in any other bike or car.
For the 1200GS you need the type that have the in built electronics that fool your on board computer in to thinking that all is normal. LED lamps use only a fraction of the power of a "normal" bulb, so the computer thinks that the bulb has blown. For an example of these LED bulb look in nippynormans Hope this helps, Cheers Stu
Rock Hard & Ride Safe. Stu 2004 R1200GS Sold ![]() 2009 R1200GS Due soon! ![]() I'm only wearing black until they find something darker! SAVED PLANET ROCK!
Sometimes I think BMW just doesn't want us adding anything other than BMW farkles Jim |
The LED tail light came out on the '08 model. It can be retro-fitted to the '04/'07 12GS with a cable adaptor, but you need to get the electrics 're-set' with a diagonstic by your friendly BMW centre. However, at least over here, they will charge you for the diagnostics time. Best bet if you really want to change to the LED rear light is to wait until the bike is due for a service and have it changed at the same time. This way, they'll not charge you for the set-up time. At least that's what my dealer told me. |
