I just could not resist to buy it when I saw it at a local shop that sells various kinds of kind of gadgets. The reason why is because the germans have given the GS the nickname "gummikuh" = "the rubber cow".
Cheers, Beemer
"Don't do whatever you like, like whatever you do!" |
that is a great idea. I really like that. Good job. I'll post a photo of a cheap mod that i did. I've done some other acces. mods, but there not pennytech mods. Are we just showing pennytech mods or anything that we did? Anyway, here you go. ACE HARDWARE $6.00 Bottle opener, left Pannier Scrap Alum. from work Adios kook |
Scrap aluminum is good. I used some to make a bracket to mount a stick on thermometer. It reads OK, now.
![]() I first tried mounting the thermometer near the instrument panel but heat from the engine is funneled in that direction causing it to read about 15 degrees too high. // marc |
I installed Lanyard's on my Fastway foot pegs, shifter, and brake lever. Just incase something came loose and fell off, I didn't want to go looking for it. Now it will just hang there. Eventually i will drill holes in the fastener heads and safety wire them.
![]() ![]() Adios kook |
