Gerbings won't work - BMW R1200GS Forum : R1200 GS Forums
Old 07-Dec-2007, 06:18 AM (512)
papawheelie's Avatar
don't trust this guy
Default Gerbings won't work
I have a 2005 gs and just purchased Gerbings jacket liner. The accessory plug will not power the jacket liner. I hear there is a firmware update that could give my power plug more juice. Anyone?
BMW R1200GS, Ducati Sport 1000 SE, KTM 530 EXC
Old 07-Dec-2007, 09:30 AM (646)
Reverend Noob
Default Nope
The latest firmware will not increase the allowable output from the accessory outlet. The easiest way to run your Gerbing heated equiptment is to pay Powerlet $29 for their adapter which runs the stock accessory outlet direct from the battery. Works as advertised, just takes the canbus out of the picture
Jim
Old 07-Dec-2007, 03:13 PM (884)
thanks, I have a centech and I can connect the power outlet directly to it. I have a wire harness connected to it now and works fine, but I want the install to look cleaner.
Old 07-Dec-2007, 07:24 PM (058)
The powerlet adapter mentioned replaces the stock accessory jack. It looks stock. How can it get cleaner than that?
I use a small fused pigtail going to the battery that hides between the saddle and the black plastic cover on the left side when not in use. You have to look for it to see it.
// marc
