Looking to add to my 2007 GS. What type of lights including mounting hardware do you recommend and why? I ride long distance (want better visibility and fog capability as well). Much apprciated!
I have this light bar
http://www.gmtmoto.com/lightmount1200.php and Hella FF50 lights. Far better than the PIAA 510's they replaced.
Kurt 2012 R1200 GS Adventure |
Thanks Kurt, perhaps you can assist me once again. I decided to order the GMT light mount and the PIAA 910's (advised that they are really great riding lights) These lights consume 170 watts. I have a GPS and StarCom as well that consume very low watts (can't recall exactly how much but low for sure.)
My bike is a 2007 GS with alternator capacity at 600watts. The supplier tells me no problem to add, wouldn't mind another opinion or two. Thanks Ride Safe Archie. |
I have mounted the Trail Tech self ballast HID lights using their horizontal posts. I mounted the posts to the bar under the front beak. Self ballasts lights allow you to wire directly to the switch and battery and you are good to do. http://trailtech.net/single_hid_scmr16.html I am having problems uploading pictures to the R1200 gs forum. But PM me and I would be more then welcome to share pictures.
I would like to connect to high beam positive wire. Lights will only operate when high beams are on. Does anyone have pictures to share or best way to find the high beam positive wire to make this connection. Much appreciated.
Ride safe. Archie |
The white wire going into the headlight is the high beam (yellow is the low beam). You may want to use a separate circuit wired directly to the battery to power your aux lights, and use a relay to switch this separate circuit on when the high beams are on. (Use the high beam wire to trigger a relay, but don't use it to power the aux lights).
