Wiring lights into the GS can-bus system - BMW R1200GS Forum : R1200 GS Forums
Old 11-Nov-2006, 06:37 AM (526)
Default Wiring lights into the GS can-bus system
In the essence of full disclosure let me say that I'm a noob to the GS, I've had mine for just under 24 hours... Another strike against me is that I lack the gene that allows me to be comfortable with electrical mods.
Despite this I wish to add caliper mounted motolights to my bike and my local BMW dealer has advised me that it is a 3 to 4 hours install by their techs. This is due to the can bus system. The "how-to's" I've seen here and at advrider make installing lights appear to be not too complicated. My question is who's right?
Old 11-Nov-2006, 11:54 AM (745)
Joel's Avatar
Default Don't mess with the CANbus
I'm so tired of all the CANbus fearmongering I could just spit.
Nobody needs to mess with the CANbus to make electrical mods. I did my own aux lights (not Motolights, however) and some other electrical mods by myself, and I'm no wizard. Connecting a fuse block with a relay to your battery is the way to start. Most of what I needed to know I found right here:
http://www.r1200gs.info/howto/relay.html
You can find other info over on advrider.com or bmwst.com, especially if you look through Jim von Baden's posts. He's done a nice diagram that shows a flexible way to power up your gear.
If I did it, I bet you can too.
P.S. Look here at Ken's post, too.
n00b, interested in purchasing a 1200 GS, questions about electronics
Old 11-Nov-2006, 03:32 PM (897)
kook's Avatar
Default Centec
Thought i'd post a pic of my setup.
I installed a Centec AP1 fuse block where the stock tool kit goes.
I run my Hella HID's, Volt meter, Gerbings vest, and 2 auxillary 12V outlets.
My HID's are wired to switched power also, you can see by the Blue wire.
Centec
Here's one of my 12V auxillary outlets installed
Adios
Bobby
Old 12-Nov-2006, 10:21 AM (681)
Time Traveller's Avatar
Default Centec Fuse Box
Kook;
Very nice and sanitary install! Is that an aluminum plate that you have the Centec attached to?
Time Traveller
Time Traveler
'05 R1200GS
BMW MOA
IBA '98
AMA CLM
"Every ride is an Adventure ..."
Old 12-Nov-2006, 12:56 PM (788)
kook's Avatar
Thanks Time Traveller. Yes, it is Alum... I hard mounted the Centec to the Alum. plate, then i used velcro along the thin edge of the recess.
kook
Old 12-Nov-2006, 04:39 PM (944)
Well, it can take a lot of time depending upon how you route the wiring. I probably took a half a day getting it the way I wanted it. Details here. Oh, that also included the time to re-route some other wiring I'd done for GPS and radar detector. I wanted all wiring to go under the tank.
// marc
Old 13-Nov-2006, 08:20 PM (097)
Thanks guys for all your responses. Based upon these responses and reading other boards I'm going to see about upgrading my comfort and skill level to make this mod myself.
Old 25-Nov-2006, 03:05 AM (379)
Default increased confidence with the can bus
hey there. i'm new on board so please excuse any format errors.
ok, i work with/for motolights and have my own comapny installing farkels, since most people fear electrical modifications. playing with the can bus is very easy once you know where to go for your power.
email me at bmwinva@comcast.net and i'll tell you more.
later
roger
Old 17-Jan-2007, 09:01 PM (125)
JimVonBaden's Avatar
Kool Aide Dispenser
Send a message via AIM to JimVonBaden Send a message via MSN to JimVonBaden
Here is my wiring diagram for my Centech fuse box. I also added a second set of lights as well. (this diagram was originally designed for a Blue Seas box, but works fine for any fuse box)
Here is the Centech box all wired in.
All my lights on.
I also have it wired for Gerbings, GPS and a Steibel horn, which are currently installed.
It was a simple job that just took a little patience, and a little time.
No need to be afraid of the canbus system. Just work around it.
Jim
Click here for the R1200 Maintenance and Accessories Videos for sale!
R1200GS with a few accessories!
Old 18-Jan-2007, 08:41 AM (612)
GelStra's Avatar
Hey, Jim, K.C. Int'l just called. They need some back-up lighting on 23R.
'05 12GS Blue
Covina, CA
