Better tire life on road with higher psi in front - 40psi. 42 psi in rear is about right. The trade off is you will have to lower the psi off road to get optimum traction (22psi ft, 24psi rr).
Dirtjet |
I'm a believer in higher tire pressure for longer tire life and better protection of the rims and tire. I was advised to do this by a "BMW Motorcycle Engineer"! I spoke directly to him on a number of subjects. He had volunteered to fill in for the guy that usually works the phone. I run about 2 lbs. under the max on the sidewall. Tom
"I ventured into the dark alley with a pounding heart and a spastic colon, hoping neither would give me away." |
