How important is it to keep the front and back tyres the same? I need to replace my rear tyre and might not be able to find the same make/model. If I have to get a different rear should I think about changing the front as well so they stay the same?
![]() Bad things will happen otherwise. |
Thanks Marc,
Thats precisely what I thought. It's just good to ask - and good to here. |
The important thing to me is that the tire manufacturers match the front and rear for performance. Mixing may create an unmatched situation that affects handling fatally.
That said, I have on occasion had to mix in transition -e.g. when I am moving from tire A to tire B and they are not equally worn. I find I wear out 2 rear tires for every front. So, if the front is worn down, I would change both to tire B. If only the rear is worn I put tire B on the rear until the front needs replacement to tire B. |
