I have run with a TKC-80 on the front and a Tourance or Trail Attack on the rear. It was a compromise to give me good tire life on the road and better control in the dirt. It worked. The bike seemed to handle better in the dirt with the front knobs, giving me a feeling of more control.
On the street the front knobs are a little noisy and the ride is a touch rough, noticeable at slow speeds. That is about the only down side. The TKC-80 sticks plenty good ONCE YOU HAVE A COUPLE HUNDRED MILES ON THE TIRE. They do seem to wiggle around a bit for the first hundred or so. I like the combination enough that I've got a TKC-80 front and a Conti Trail Attack waiting for my next tire change. |
One of the bigger problems that I have is that there is a lot of sand in southern Utah. Most of the dirt roads that I hit are sandy in one place or another. I usually end up digging my back tire into some sand while trying to get traction. The front of the GS is a little heavy and the front tire doesn't want to float across the sand as much as my dirt bike.
In the future, I would really like to try a sand paddle on the GS at the sand dunes. For now I'm sticking to the dirt.
'05 R1200GS |
The TKC80s are a well proven all round choice with a bias to dirt. They perform great in sand and dirt and ridden smoothly, you could probably touch down your pegs. They of course move around a little but you soon become accustomed to that. Plenty of info available on this subject.
On sand, drop your tyre pressures to 25 PSI this makes a big difference in control. Carry with you a small 12v tyre pump and a quality tyre gauge. Huge improvement you will appreciate. Saturn 5 R1200GS V-Strom 650 |
