Tire wear is dependent upon many things. You mentioned pressure. Other items that effect wear are your right wrist and the makeup of the roads you ride. Some roads are smoother than others. And the makeup of the tire, of course.
I get anywhere from 6K to 11K per tire. Because of the wide range I ignore mileage and look at tread wear. The only gotcha when going on a long trip is that some tires wear faster as they get older. There's no rule that says you can't put a new tire on the bike mid trip. It might cost you a bit more than normal, though. BTDT. |
