I am terrified - BMW R1200GS Forum : R1200 GS Forums
post #1 of 8 (permalink) Old 16-May-2017, 07:23 PM (016) Thread Starter
I am terrified
Despite of think of my self a good mechanic. Being a mechanical Contractor, and being had several bikes,even Put an audiovox cruise control in a VStrom, i am terrified to touch the bmw not to mention the cam bus, them I have read what people do in theirs, and i astonished, so I hope this forum help me to go ahead.
I want to put a battery tender, can I disconnect the battery, put it back without any problem to the computer/ecu?
let me mention the I got a gs lc 1200 2014 with 2400 miles, fully loaded, with lots of accessorizes for 16k plus and after market warranty until 2022 and 150000 miles
love the bike, the ride ever had.
luisc500 is offline
post #2 of 8 (permalink) Old 17-May-2017, 01:46 AM (282)
Houdini's Avatar
You can remove the battery. All settings will be preserved.
Make sure you use the safest method of disconnecting the negative terminal first and reconnecting it last.
Current: 2013 R1200GS LC
Houdini is offline
post #3 of 8 (permalink) Old 17-May-2017, 08:38 AM (568)
The ride of Life
Bumblebee's Avatar
To add a battery tender just grab an SAE pigtail (one comes with it when you buy it, also available separately) and directly connect it to the battery. Route the pigtail down on the R/H side of the bike and tie wrap it to the frame. Done. The battery comes out the right hand side of the bike, it's behind the R/H side plate. You can use that SAE plug to power other items too.
Second option is to get the BMW "Canbus" battery charger, then just plug it into the accessory outlet. This charger communicates with the electronics on the motorcycle and turns on the accessory outlet when it's plugged in. Good clean way to charge the battery but that gizmo is stupid expensive for a battery charger, but its really tetchy cool! How may people can say they have an LCD display on their battery charger?
IMHO, the CANBUS system should be left unmolested. Power and data run over the wires that feed the various electrical loads on the motorcycle. Every load is monitored by one of several controllers, if excess power is drawn the controller will shut the load off. If a "foreign" electrical load is connected to the motorcycle systems the flow of data can be compromised causing all sorts of issues.
The solution is to either go directly to the battery, or connect the battery to an electrical distributor block, this adds multiple connections and fuses each one. This is the accepted way to add electrical loads to your GS.
This video shows you what a $200 battery charger looks like:
- John
The Ride of Life.
Last edited by Bumblebee; 17-May-2017 at 08:59 AM (583). Reason: More Stuff. We all need more stuff.
Bumblebee is offline
post #4 of 8 (permalink) Old 17-May-2017, 08:58 AM (582)
You don't even need to wire leads to the battery for a battery tender. You can buy units specifically for the bike that just plug into the accessory outlet next to the instrument panel.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Weir1200GS is offline
post #5 of 8 (permalink) Old 17-May-2017, 09:48 AM (616)
The ride of Life
Bumblebee's Avatar
Just checked that out, a much better and $100 cheaper option. But, still no graphic LCD display to impress your friends with.
The Ride of Life.
post #6 of 8 (permalink) Old 17-May-2017, 11:28 AM (686)
Its a really nice unit and tests the batter each time you plug it in. It then auto-detects whether it should charge or must "maintain" the battery and it shows you what it's doing via a series of lights. It actually works WITH the CanBus instead of bypassing it.
post #7 of 8 (permalink) Old 17-May-2017, 11:31 AM (688)
If you want to send me an extra $100, I'll apply a little BMW sticker to the Optimate unit to give you that "genuine BMW" accessory touch.
I'm not saying the BMW unit isn't great; I have no experience with it. Just saying the one I bought works really well and is ever so simple to use.
post #8 of 8 (permalink) Old 17-May-2017, 06:41 PM (987) Thread Starter
i agreed with not molest the cambus, on the other hand, the charging in the plug is neat
thanks every body for the help
luisc500 is offline
