Changing brake lever. - BMW R1200GS Forum : R1200 GS Forums
Old 11-Nov-2010, 10:54 PM (204)
slojon
Default Changing brake lever.
I have to change the brake lever of my 08 GSA. It looks easy but there seems to be a knack to doing it. Any help muchlee appreciated.
Ta Jon.
Old 12-Nov-2010, 12:11 AM (258)
schuppi's Avatar
Hi Jon
Yes, it seems to be easy.
But after mounting the lever, you have to look for the right adjustment of the brake piston pusher and the brake light switch.
Wrong adjustment follows fatal malfunction of the brake system.
Right function will be controlled by BMW diagnostic system GT1
Brake lever (6) only for repair by dealers ( Germany )
So please be carefully
allways stay on top of your motorcycle
Old 12-Nov-2010, 10:39 AM (694)
Hand brake or foot brake?
For the hand brake you remove the nut, put the screw out of the housing, then pull the lever assembly back. There is a rubber sleeve (item 4) that holds the lever to the piece with the rod. You've got to remove the sleeve to remove the lever. Watch out for the spring.
And all of that assumes that the '08 is the same as the earlier bikes.
