Sticky throttle with heated grips - BMW R1200GS Forum : R1200 GS Forums
Old 25-Nov-2010, 09:40 AM (652)
Default Sticky throttle with heated grips
Anyone have a problem with the throttle getting sticky when the heated grips are turned on? I'm assuming something becomes sticky inside the grip when it becomes hot, but I can seem to find any issues.
The stickyness starts about 1 minute after turning on the grips, and feels a lot like my throttlemeister cruise control adjusted to a low/medium setting.
I can remove my hand from the throttle and it very slowly returns to normal.
It's just irritating and not extremely safe.
Thanks for any comments.
Old 25-Nov-2010, 11:53 AM (745)
It likely is your throttlemeister. The grips expand when they get warm. Their lengthwise expansion can make them hit the end of the throttlemeister. The solution is to position the throttlemeister a bit further from the end of the grip.
And a warning: If the throttlemeister is in use when you turn on the grips the throttle can get very hard to turn. On some bikes it can cause either the grip assembly or the throttlemeister to move, rendering the throttlemeister inoperable until the positioning is corrected.
Old 01-Dec-2010, 09:19 AM (638)
wilk's Avatar
I agree that it is the throttlemeister. I have had the same problem, haven't yet thought about fixing it.
R1200GS 2005
former Kawasaki ZR 7s
former KLR 650
Old 02-Dec-2010, 07:28 PM (061)
Thanks for the info Marc. That's kind of what I figured. I already have one washer between the throttlemeister and the bar, and when I add another one the Throttlemeister is to far away from the grip where it doesn't work properly. I guess I need to decide if I want warm grips or cruise control? Or warm grips with a real sticky throttle that drives me crazy.
I appreciate your help.
Old 07-Dec-2010, 07:12 PM (050)
doesn't it suck when you have to compromise - sometimes we all just want it ALL..
