I think your battery is dying. My '09 GSA was exhibiting the symptoms you describe and I dropped a new Odyssey into the battery box. That cured the charging problem. How old is your battery?
Mike |
Here is a link to a tasty little trouble shooting farkle that is a plug
into a cigarette lighter Battery and Charging system monitor. It has a digital readout and around 15 USD. It gives a real time continuous look at what the alternator is doing.
The GS sucks a lot of current from a very small battery. Here's a graph of start up voltage from my bike. ![]() That makes me think a fully charged healthy battery will drop further than 11 volts on these bikes. The numbers were captured with a GS-911. A Fluke meter at the battery showed a slightly higher voltage than the reported numbers. |
I will bet with 95% certainty that your battery is the problem. 14.3 to 14.4 volts while running says alternator is good. A battery with 12.4 to 12.6 is only about 40 to 60% of full charge which means it needs a refresh charge. It should normally be between 12.7 and 12.9 volts to be fully charged. As high as 13 volts after a full out of the bike charge.
I just bought my bike and it seems to me that this bike is somewhat of a battery hog. Even with a new battery, the starter is not overly "enthusiastic".
R1200GS 2005 former Kawasaki ZR 7s former KLR 650 |
What Odyssey battery? I have read lots never seen the part number. I have also seen a couple where they trim them to fit?
My 05 is surly lately and I was thinking the battery might be the culprit. I tend to go to the cycle gear and buy their "megaboost" battery. It's not necesarily "good" but lifetime replacement.
01/09 DRZ470SSW more bits than necesary 2005 R1200 GS AKA The Mothership 2003 Z1000 Nuclear Pumpkin (gone) 1986 RG500WW (gone) Bikes are like women. What you think you want, and what you want, change after the first ride. |
I odered my Odyssey PC 535 here: Mike Last edited by mikec; 02-Dec-2010 at 02:00 PM (833). |
I got some surfing time in and hit ADV. I saw both the 535 and the 625 (!) not sure why the bigger higher output battery is cheaper.
Both looked a little fiddly but the 535 was definitely easier. The bigger one appeals to the more power me inside though. I will see how mine stands up then decide which way to go. The cycle gear CTX14-BS is $90 with lifetime it should be approximately the same as stock. I would prefer to upgrade though. As weak batteries suck and it seems the BMW systems are voltage sensitive
